timmer547 Posted July 11, 2010 Report Share Posted July 11, 2010 I'm looking to install a emergency siren in my 2009 Journey. Trying to find a place to install a speaker in the front under the hood preferably. Its very tight in there unknown where to mount it. Tried taking the inner fender off on the driver side front by the battery but cannot put it under there not enough room. The next option was behind the grill. have to take the grill off. Anyone know how to do that? here are the dimensions of the speaker and other information about it Dimensions: 6.34" H x 6.75" W x 2.96" D Specifically designed for narrow & small spaces - just under 3" thick. Can be mounted horizontally or vertically with adjustable bracket. Quote Link to comment Share on other sites More sharing options...
email4walker Posted July 14, 2010 Report Share Posted July 14, 2010 I'm looking to install a emergency siren in my 2009 Journey. Trying to find a place to install a speaker in the front under the hood preferably. Its very tight in there unknown where to mount it. Tried taking the inner fender off on the driver side front by the battery but cannot put it under there not enough room. The next option was behind the grill. have to take the grill off. Anyone know how to do that? here are the dimensions of the speaker and other information about it Dimensions: 6.34" H x 6.75" W x 2.96" D Specifically designed for narrow & small spaces - just under 3" thick. Can be mounted horizontally or vertically with adjustable bracket. When you open the hood, look left and right of the hood latch, you should see black button style pins. Use a screw driver to pull them out. Look in the wheel well and you will see some more. Remove them too if you need to. Once you do that, you can get behind the grill/bumper. Quote Link to comment Share on other sites More sharing options...
wally9868 Posted June 18, 2016 Report Share Posted June 18, 2016 I know this post is way old but I to am trying to install a siren and am ha sing the same problem. Did you ever find anything that worked? Also, where did you run the wires through the firewall? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 18, 2016 Report Share Posted June 18, 2016 (edited) Why? Impersonating a cop? Edited June 18, 2016 by jkeaton Quote Link to comment Share on other sites More sharing options...
OhareFred Posted June 18, 2016 Report Share Posted June 18, 2016 Voulnteer firefighter/EMS perhaps...... Quote Link to comment Share on other sites More sharing options...
