fpinder Posted July 25, 2010 Report Share Posted July 25, 2010 Did anybody found out how to reset the engine light on a Dodge Journey? Quote Link to comment Share on other sites More sharing options...
warbird24 Posted July 25, 2010 Report Share Posted July 25, 2010 If it is the "Check Engine" Light that is part of the OBDII system and a user can not reset it. You have to correct the problem first and then allow the system to reset itself. These lights can be as simple a problem as the gas cap not being on tight enough, or as complex as a engine misfire. At least have someone read the code and see what it could be. Many Auto Stores provide these services. Quote Link to comment Share on other sites More sharing options...
johny1fin Posted July 25, 2010 Report Share Posted July 25, 2010 If it is the "Check Engine" Light that is part of the OBDII system and a user can not reset it. You have to correct the problem first and then allow the system to reset itself. These lights can be as simple a problem as the gas cap not being on tight enough, or as complex as a engine misfire. At least have someone read the code and see what it could be. Many Auto Stores provide these services. I have the light on only twice and the reason being a flat battery. It took a few miles (<20) of driving before it went out on its own. Maybe this was after the canbus adjusted itself after false default settings. Book says if its a constant light it may be ok but if its flashing do not drive as it may damage the exhaust system. John Quote Link to comment Share on other sites More sharing options...
