Compass Calibration
journeymanny
The compass is looking to be 'calibrated' Usually calls for driving in a circle away from metal structures. Should be explained in the manual,
page 225 of said booklet says this:
Automatic Compass Calibration
This compass is self-calibrating, which eliminates the
need to calibrate the compass manually. When the vehicle
is new, the compass may appear erratic and the
EVIC will display “CAL” until the compass is calibrated.
You may calibrate the compass by slowly completing one
or more 360-degree turns (in an area free from large metal
or metallic objects) until the “CAL” message displayed in
the EVIC turns off. The compass will now function
normally.
normally.
Cool! Thanks man
