Problems with homelink
My wife recently purchased a 2010 R/T with all the bells and whistles (Homelink equiped). I spent about an hour tonight trying to get the homelink to work . I have a Chamberlain Liftmaster 1200 series garage door that was installed in 2004. I assume this model uses a "rolling code". I tried both procedures several times as outlined in the manual to get a good link. No go. Any suggestions?
  On 9/13/2010 at 3:25 PM, scoe54 said:
Worked first time for me with two separate doors. My openers are Chamberlain as well (not sure of model). Did you clear the memory each time before you tried to program? Probably want to ensure your remotes have fresh batteries as well.
Thanks for the reply. Do I need to clear the memory on the garage door opener as well as the homelink system?
  • 3 months later...
never got any luck with the Genie Chainlift garage door opener, 3 cars, same problem. Seems to program, just doesn't work, just ended up attaching the keychain remotes to the upper left corner of the windshield. Pisses me off, but I'm over it.
Finally it worked, both on the Journey and the 300M. Follow the instructions below (received from Homelink)
Rolling Code Programming:
1. Press and hold the two outer HomeLink buttons until the indicator light
begins to flash (after 20 seconds)or the display reads "Channels Cleared".
Do not hold for longer than 30 seconds. Do not repeat this step to program
additional HomeLink buttons.
2. Place the hand-held transmitter 1-3 inches from the HomeLink button you
want to program.
3. Simultaneously, press and hold both your HomeLink button and your
hand-held transmitter. Do not release either button until step 4 has been
completed. (If you reside in Canada, refer to the "NOTE" below.)
4. When the indicator light changes from a slow blink to a rapid flash or
the display reads"Channel Trained", release both HomeLink & hand held
transmitter buttons.
5. Then go to your garage door opener motor head unit in the garage.
Locate the "Program" or "Learn" button. Usually near the hanging antenna
wire on your garage door opener motor head unit. (The name of these
buttons vary by manufacturer, please see your garage door openers owners
manual for the location of this programming button).
6. Press and release the "Program" or "Learn" button once, like a door
bell (1 second)(Do not hold this button down. Holding this button down for
too long will erase all Remotes, Keypad and other HomeLink equipped
vehicles). There is 30 seconds in which to initiate step 7.
7. Then go to your vehicle and firmly press and hold your already
programmed HomeLink button for three seconds and release. Do this
procedure a second time and depending on the Brand of your garage door
opener you may need to do this step a third time to complete the process.
The garage should now activate when the programmed HomeLink button is
firmly pressed and released. If not, give us a call or refer to the
"Troubleshooting Tips" noted below.
NOTE: If you reside in Canada, replace step three with the following:
Press and hold the desired HomeLink button and "cycle" the hand-held
transmitter. To cycle: Press and release the hand-held transmitter button
every two seconds until the indicator light changes from a slow blink to a
rapid flash(step four).
