a/c smells urine
kered118
Cleaning the filter is impossible, you need to replace it. It is behind your glove box.
- Open the glove box completely.
- On each side you need to pull a stopper to the innner side.
- Open the glove box further, release the "wire" on the right center side
Now you will see the A/C vent unit, with on top the filter holder. Remove this, replace the filter and install backwards.
Very simple, 2 minutes work (first time maybe 10 minutes). You can also check your owners manual : Page 416.
I do not think that the filter is the issue....................................
hi, i have heard that you can spray lysol in the intake to kill the mildew but I dont know where to find the the intake thing.thanks
  • 3 months later...
+1 on changing the filter. My Volvo S40 had about the same smell. Nothing worked taking the smell away
