Journey problems with electric
zuram
Hi!
Car produced in 2008, 2.4.
When I tried to turn the ignition switch, nothing had happened. Fuses are ok. The battery is also full. Does anybody have an idea what could it be? Why I can't start the car? Thx.
Posted 30 September 2010 - 09:44 AM
View Postbrwengel, on 28 September 2010 - 04:04 PM, said:
Not sure if this is your problem, but I remember reading about someone who had a problem with the switch that determines if the tranmission is in park. There are a lot of conditions that must be met to start one of these cars. As the above poster mentioned it could also be the key fob, so you could try your other fob and see if it makes a difference.
Happy Motoring, and let us know what you find the problem to be.
This is exactly what it is. The vehicle won't start if it's not in park, so you have to jiggle the shifter back and forth when in the park position. This is only a quick fix solution to start the vehicle. I believe the solution is replacing the TRANSMISSION RANGE UNIT OR SELECTOR. I had the problem for a year but once it was changed 3 months ago it hasn't happened since. Hope this works for you!
