wraith13 Posted October 18, 2010 Report Share Posted October 18, 2010 I just purchased a 2010 awd rt and it has the 19'' wheel/tires. I have read that the 5 hole pattern is 127mm and read somewhere else that it is 114mm? So does anyone know for sure what it really is? The dealer/saleman said that my nitro 17'' rims should fit....not to sure about that. Will a gm 16'' wheel fit, if not what should I look for? Also what tires are you guy running of your 19'' rims? cheers, John Quote Link to comment Share on other sites More sharing options...
email4walker Posted October 18, 2010 Report Share Posted October 18, 2010 I just purchased a 2010 awd rt and it has the 19'' wheel/tires. I have read that the 5 hole pattern is 127mm and read somewhere else that it is 114mm? So does anyone know for sure what it really is? The dealer/saleman said that my nitro 17'' rims should fit....not to sure about that. Will a gm 16'' wheel fit, if not what should I look for? Also what tires are you guy running of your 19'' rims? cheers, John 127mm is the right size. make sure the offset is correct also. I believe it is 40mm or 35mm. If I remember right, both will work. Quote Link to comment Share on other sites More sharing options...
