need more information. The car's battery or the Key's battery?
So u mean, u replaced the car battery, and now the key doesn't work?
What about your 'other key'?
If all your key says bad key, all you can do is sent it to the dealership and try to reprogram them, If that fails, you probably need a new Key or WIN module. I hope you are still under base waranty, those keys and expensive.
When you turn the key on, does all the lights on the dash lights up? What instead of using the key, try to stick ur finger into the ignition cyln and turn it to key ON? now what does it say?
