Thanks for the reply. I did find a leak on the hose that connects the two fuel rails. I'm gonna change the purge valve anyway, the car has 149000 on it so I'm calling it a maintenance part! BTW, This 2012 Journey is a pain to work on!! I had an exhaust  leak on bank 1 exhaust manifold/Cat. What a stupid design!!! I ended up having to take it to a shop, couldn't do this in my garage. No more front/AWD vehicles for me.
The plastic push connectors only have an oring doing the seal, as you have probably figured out. . Sometimes just reseating them will stop a drip.
They are used on all the newer cars with plastic lines. A new oring might be available from the dealer if you have to change it.
