Whit Posted September 16, 2023 Report Share Posted September 16, 2023 While running wire for strobe lights, I accidently broke the flipper arm off the stop light switch on my brake pedal. Not a problem. I went to the local AutoZone and got the only stop light switch in 50 miles. I put it in this afternoon. However, its not reliable. The brake lights will still stay on. If I manually rotate the flpper arm toward the driver's seat, the brake lights will go off and stay off. But if I press the brake pedal, the brake lights will come on and stay on. I've tried several things to make this work, and so far, no luck. The lights will go off after a couple of minutes, though. I'm at my wits end. I've never had an issue swapping out brake switches on other cars. What should I do next? Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 17, 2023 Report Share Posted September 17, 2023 go det an OEM switch i would guess,did the replacement look identical to the old part? Quote Link to comment Share on other sites More sharing options...
Whit Posted September 17, 2023 Author Report Share Posted September 17, 2023 It looked identical to the OEM part. Quote Link to comment Share on other sites More sharing options...
