Adding Bluetooth Receiver
So my 2018 Journey doesn't have bluetooth standard for some stupid reason. But has a CD player, SD Card reader, USB port and 3.5mm Aux Jack. The Usb only works with Apple iPhones/iPods. I use an Android Device, which supports LDAC (which is a high fidelity bluetooth essentially)
Obviously even adding a new OEM BT module wouldn't allow for LDAC support anyway. So my idea is this.
Buy a Bluetooth receiver that supports LDAC, and that can be power via the USB 5v.
I can use the AUX jack into the radio. Thought using an AUX input isn't ideal and can cause line noise.
So I'd like to splice an RCA input into the radio. Just not sure where to find input on the radio.
Then install the RCA to the BT receiver. Then some decent quality BT Signal.
