2013 JOURNEY v6 3.6
chojh0049
Hi everyone, im machanic.
i have repaired for 2013 JOURNEY v6 3.6 ( water pump, thermostat, radiator, coolant hose)
but it is still temperature going to be high when 80km/h on cruise
radiator fan working well and everything looks no problem
i m sure why this problem coming.
Did you check the reservoir tank for cracks or replace the radiator cap on the res. tank? IF that does not fix things, then you may be into deeper engine troubles.
Does this Journey have rear heat? Air entrapment in the cooling system is a big quirk on these motors when opening up the system. DO NOT "fill and go", run the engine with cap off{keeping an eye on digital temp}, shut down and let cool off, top up coolant if needed and then repeat BEFORE driving with cap installed. This has worked for me with my 3 Journey's.
Good luck, and please report back how things go.
AND welcome to the forum!
i have cheked the reservoir tank's cracks and change new radiator cap but it is still same problem.
yes i will try to be like what you teaching me for tomorrow.
thank you for your answering.
Edited by chojh0049
