woodslisa153 Posted January 17 Report Share Posted January 17 The battery on a 2014 dodge journey limited keeps going dead. I can jump it and it does fine for a few stops or maybe even a few days and then it does it all over again. Any suggestions? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 17 Report Share Posted January 17 Get the battery tested and replace if needed. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
MartyZ1 Posted January 17 Report Share Posted January 17 I installed a 6a/1a charger maintainer under the hood on my 2010 base 2.4. Hooked it to the block heater plug, clipped the leads to the top battery jump points. I also have a couple of digital voltage meters that plug into the cabin's "on" 12v plug to monitor. Fought with it last winter until I installed the larger charger instead of little maintainer I had used and it starts everytime now. And this winter is real cold in the Northeast. See if theres a 120 v plug under your hood on drivers side, if not just run it. Quote Link to comment Share on other sites More sharing options...
