jmjit Posted November 21, 2010 Report Share Posted November 21, 2010 Just got back from Vegas from a Softball Tournament. I drove about another 500 miles i am now at 6000 plus.I still have not had 1 issues or 1 complaint.I did read about the 5mph lag in cruise control which is true,but it is was any lower it would be shifting up and down every time you hit a small incline so i get the 5 mph thing...i also met a Journey with 40,000 miles driven and the had nothign but good thngs to say about thier Journey.. Thats is all till next time............. Quote Link to comment Share on other sites More sharing options...
Burn Posted November 22, 2010 Report Share Posted November 22, 2010 .I did read about the 5mph lag in cruise control which is true,but it is was any lower it would be shifting up and down every time you hit a small incline a quick fix on the highway is to put the shifter in autostick mode that way the cruise control can't shift for you and it stay in gear #6 ..... Quote Link to comment Share on other sites More sharing options...
jaymista Posted November 23, 2010 Report Share Posted November 23, 2010 How do you do that? Put the shift down where the +/- signs are? Quote Link to comment Share on other sites More sharing options...
Burn Posted November 23, 2010 Report Share Posted November 23, 2010 How do you do that? Put the shift down where the +/- signs are? Exactly , when you put the shifter at the +/- position the cruise control no longer have control of the gears but YOU will.. so it will not shifting up and down every time you hit a small incline. If you do need more power shift down/up yourself as needed. When you go downhill with a big incline with the cruise control enabled the transmission will down shift and the engine will rev high trying to keep the selected speed but i just hate this behaviour....so this is why i use the autostick mode , it shift when i want . Just try to not forget the shifter in the autostick mode Quote Link to comment Share on other sites More sharing options...
