Locks overrides by door handle when transmission in drive
Safety issue not to open. In a crash or accident going into water, you need to be able to get out, even if ignition is on and maybe car running.  If your wearing seat belt, open door not really a hazard imo?
The rear doors locks each have a small manual switch for child safety over ride. If manually activated  the inside rear doors can’t be opened from inside.  One slide switch close to latch on each rear door.
All cars I have owned opening the front door handles on the inside unlocks doors., even if already locked.  Except rear doors with child over ride locks , if vehicle has the option.
If seat belts not being used, airbags not designed to fire. Too dangerous.  So BCM wouldn’t trigger to unlock doors. Still have to be able to get out of vehicle.
Hatch can’t be opened from inside, no handle or release.
Front  car doors working like they should.  Auto locks activate around 25 ish kms to lock all doors.
Edited by John/Horace
