MusicMasters Posted February 5, 2024 Report Share Posted February 5, 2024 Wife was driving our 2017 Dodge Journey SXT (3.6L) AWD yesterday on a residential street when suddenly there we wining sound and no power. Car went into limp mode for about 1 block and then wouldn't go any further. Tons of transmission codes (P0731 gear 1 incorrect ratio, P0732 gear 2 incorrect ratio, P0733 gear 3 incorrect ratio, P0846 Transmission Fluid Pressure Sensor B circuit, P0992 Transmission Fluid Pressure Sensor F circuit, P083A, P083B, P084A... No signs of external trauma (i.e. no leaks), never given us a lick of trouble... just suddenly won't run. Are we looking at a bad pressure pump? torque converter? controller? Any hope Chrysler/Dodge will cover this on a warranty as our original 7/70K has passed? Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 5, 2024 Report Share Posted February 5, 2024 Probably not,sorry it happened to you larryl 1 Quote Link to comment Share on other sites More sharing options...
Engineerbasher Posted February 18, 2024 Report Share Posted February 18, 2024 I had something similar happen, I changed the transmission filter and fluid, it restored functionality for 2 weeks and did it again, after the second filter and fluid change it's been just fine. I've been told that the filter can get plugged and starve the internal pump. Quote Link to comment Share on other sites More sharing options...
Engineerbasher Posted February 18, 2024 Report Share Posted February 18, 2024 https://www.dodgejourneyforum.com/topic/17291-transmission-seems-to-be-slipping/ Quote Link to comment Share on other sites More sharing options...
