Everythingtried Posted February 22 Report Share Posted February 22 So I have a 2009 dodge journey sxt I am pretty sure the Engine is a 3.6 just got it replaced and my car is still overheating the radiator comes on when the car gets to the middle or half on the temperature gauge I also flushed it with a hose and water goes straight through and my heater core has been bypassed. When I look under the hood there is alot of pressure in the water reservoir and when I release it the temp gage goes back down so idk what's causing the pressure to build up. Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 22 Report Share Posted February 22 2009 had a 3.5 engine, so what temp is it going to ? are the fans coming on? are you using coolant mixed right? sounds like you need to return too who ever changed your engine out before you overheat it larryl 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted February 22 Report Share Posted February 22 A 2009 model would be the 3.5 motor if this is the V^. Also being that old, I would bet on needing a new radiator, even though you say you flushed it. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 22 Report Share Posted February 22 Moved to the correct section. Quote Link to comment Share on other sites More sharing options...
larryl Posted February 22 Report Share Posted February 22 Thermostat installed correctly on the new engine? 2late4u 1 Quote Link to comment Share on other sites More sharing options...
