User8675309 Posted March 29 Report Share Posted March 29 (edited) Hello all. I was in a fender bender last year and since getting the car back, the passive entry on the passenger side (2017 DJ) no longer works. Saw somewhere that there was a code that could be reset or something, dealership says that’s not a thing, that it’s probably a “faulty clip” or something. Drivers side works just fine. Any ideas? Edited March 29 by User8675309 Left out year Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 29 Report Share Posted March 29 I have a 2011 that the drivers door passive{touch the handle} did not work and had an EVIC message to service keyless entry system. It was broken wires in the door handle. A common problem as the wires were too short for constant flexing for this year. I took the handle off and apart and repaired/lengthened the wires and all has been fine for more than 4 years. You state a fender bender, was that door damaged by the accident? lots of wires run thru the door and jamb in the rubber boot between door and body, quite possible a wire for passive entry was damaged/cut. NO WAY to tell you exactly what is your fault sight unseen. Keep on the folks that did the repair and your Ins. Co. to get to the bottom of the problem and get it fixed, GOOD LUCK and PLEASE report back what transpires. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 29 Report Share Posted March 29 as 5rebel9 posted above IF it hasn't been to long from the acc/repair get the body shop to check it out but as been said probally a wire at the door jamb is mostly the culprit or the door handle Quote Link to comment Share on other sites More sharing options...
