David Thompson Posted April 1, 2024 Report Share Posted April 1, 2024 Randomly goes into limp mode , might be 200 miles might be 20 feet. Shows these codes U0416 U1110 U1120 U110A U1412 U11bc Where to start? Quote Link to comment Share on other sites More sharing options...
larryl Posted April 1, 2024 Report Share Posted April 1, 2024 reads like battery or ground issue to many things happening at once? 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Dean H Posted May 19, 2024 Report Share Posted May 19, 2024 (edited) Here you go - U1110 Lost vehicle speed message. U1120 lost wheel distance message U1412 implausible vehicle speed signal U11bc lost brake switch message U0416 implausible data received from ESP. Electronic stability program. These are all signals that come from the ABS (anti-lock brake module) to the PCM. They are missing. You need to check out the wiring to the abs module. Wheel sensors too. After that, I would replace the ABS module. On the journey the ABS and the hydraulic control unit are combined. Called the integrated control unit. ICU. Someone with a capable scan tool. Has to initialize and bleed the ABS. After you replace it. Edited May 19, 2024 by Dean H Quote Link to comment Share on other sites More sharing options...
Dean H Posted May 19, 2024 Report Share Posted May 19, 2024 With scan tools. They start at basic code readers. Go up to bi-directional controls. Where you can actuate components with it. Relearn procedures etc. You need a shop with good scan tool capabilities. Ask them up front. That can check and test abs wheel sensors. ABS module testing as well. They can solve this the quickest. John/Horace 1 Quote Link to comment Share on other sites More sharing options...
