MarkCee Posted April 25, 2024 Report Share Posted April 25, 2024 I recently picked up low-mileage (28K) 2018 and discovered that the front windshield washer was not doing much but dribbling out when activated. I opened the hood to check connections and all are good. While I had the hood open I also cleaned out the emitter orifices with a needle. I left the hood propped open, got back in the vehicle and ran the washer and it sprayed like a champ. Closed the hood and tried again and back to just a dribble. To clarify, with the hood closed the emitter on the driver's side 'dribbles', the passenger side emits nothing. The lines appear to be running along their proper route, so don't think anything is getting kinked when I close the hood. Any suggestions? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted April 26, 2024 Report Share Posted April 26, 2024 (edited) Crap in the lines maybe. Flush out a bit before nozzle outlet. Check bottom of reservoir for grit. Hood jets fragile and pricy, be careful. How is hatch spray, normal. There are two pumps on system. Edited April 26, 2024 by John/Horace Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 26, 2024 Report Share Posted April 26, 2024 well if it works okay with the hood up BUT doesn't when the hood is closed then you have a restriction somewhere,, the journeys use the plastic little lines, mine was cracked on the drivers side at the rear of the hood by the hinge, I replaced most of my squirter lines with new rubber lines and the good thing is the rubber lines fit tight and just slide over the plastic lines so you don't need any clamps when splicing the rubber lines onto the plastic lines Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted April 26, 2024 Report Share Posted April 26, 2024 (edited) On 4/25/2024 at 1:19 PM, MarkCee said: I recently picked up low-mileage (28K) 2018 and discovered that the front windshield washer was not doing much but dribbling out when activated. I opened the hood to check connections and all are good. While I had the hood open I also cleaned out the emitter orifices with a needle. I left the hood propped open, got back in the vehicle and ran the washer and it sprayed like a champ. Closed the hood and tried again and back to just a dribble. To clarify, with the hood closed the emitter on the driver's side 'dribbles', the passenger side emits nothing. The lines appear to be running along their proper route, so don't think anything is getting kinked when I close the hood. Any suggestions? Expand If spraying with hood open, LOOK on the drivers side at the hood pivot area. The washer line makes a 180* bend there to go into the hood spray nozzles. 2 of my 3 DJ's had that area kink and one was actually broken. I repaired with flexible hose with a little extra length so the original layout of this hard plastic line does not bend so sharply. Also on my third DJ a washer nozzle had a broken fitting for the supply hose to hook up to, This one had enough to reconnect back and I used a mini tie strap to hold it on, just like using a hose clamp. This problem made both nozzles ineffective as they run on the same supply line through the hood. Good Luck! Edited April 26, 2024 by 5rebel9 2late4u 1 Quote Link to comment Share on other sites More sharing options...
MarkCee Posted May 17, 2024 Author Report Share Posted May 17, 2024 Thanks all for the replies and sorry for the late update. Upon closer inspection I did find a bend/kink in the plastic at the turn leading to the nozzles. When the hood was closed, the kink closed up completely, causing the issue. I cut out the bad piece and spliced in new line. 5rebel9, 2late4u and larryl 3 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted May 17, 2024 Report Share Posted May 17, 2024 On 5/17/2024 at 3:57 PM, MarkCee said: Thanks all for the replies and sorry for the late update. Upon closer inspection I did find a bend/kink in the plastic at the turn leading to the nozzles. When the hood was closed, the kink closed up completely, causing the issue. I cut out the bad piece and spliced in new line. Expand glad to help out and that you have corrected your "situation"! Quote Link to comment Share on other sites More sharing options...
