Yogitech1 Posted May 1 Report Share Posted May 1 How can I stop my driver door window from sounding like a witches nails on a chalk board when I roll it up or down? My ears hurt. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 1 Report Share Posted May 1 (edited) Lubricate the tracks. Edited May 1 by jkeaton Quote Link to comment Share on other sites More sharing options...
Yogitech1 Posted May 1 Author Report Share Posted May 1 I have lubricated it but, it just comes back in a couple days. What lube do you suggest? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted May 3 Report Share Posted May 3 Need to remove inner door panel and see what’s going on. Often there is a scissor type mechanism bolted to bottom of door window track. Needs to be able to pivot freely and self centre as window is guided upwards. If a bushing is worn or something is sticking the sides of window will bind and create noises. A few different styles of window mechanisms out there. I’ve never looked at a Journey one, so they must be fairly durable. Have played with other brands. Inspect and/ or replace window regulator assembly…could be in play. Watch your fingers. Free advice worth everything you pay for it. Quote Link to comment Share on other sites More sharing options...
Yogitech1 Posted May 3 Author Report Share Posted May 3 No scissor bar in this one, it has power windows run by cable.if I lube the front rail it goes away but, doesn't last. Quote Link to comment Share on other sites More sharing options...
