egull Posted May 5 Report Share Posted May 5 I have a 2009 journey 3.5 L SXT the cruise control went out. The right side of the dash were the mileage indicator is blank. I called the dealership and they said fuse number 37 to check to see if my cruise control work. It’s at 10 AM fuse I checked all the 10 AM fuses and the fuse box and they’re all good. I bought a new cruise control arm. Is there any directions on how to remove that? Do I need to disconnect the battery being it there on the steering wheel with the airbag any suggestions would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted May 5 Report Share Posted May 5 (edited) I have DJ's with wheel mounted controls, not stalk mounted. BUT if the Check engine light is on, it is supposed disable the cruise control function. Might this be your cause????t Edited May 5 by 5rebel9 Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 5 Report Share Posted May 5 abs and traction control lights will also deactivate cruise control Quote Link to comment Share on other sites More sharing options...
