Patoriku Posted May 18, 2024 Report Share Posted May 18, 2024 2010 Dodge - Journey SXT - 3.5L, V6, 260.000 km I'm happy to ETRANSFER some money if we find the culprit! Main problem: Speedometer doesn't work when driving * it's reading more less correctly first 3~5 mins after starting, goes to 0 mph after * it's moving on an instrument cluster check * it's moving randomly after the engine starts and sometimes in high speeds * it's moving a little bit when the car is revving (looks like the car has these "fluctuations") * also many icons on my cluster don't work (see pic down) I've tried: 1. Changing Vehicle speed sensor (VSS) - didn't fix, back old one 2. Changing Front left Wheel Sensor - didn't fix, back old one >> Each shop basically tried one of each sensors, didn't help, sent me home. Notes: - car is shifting fine - battery voltage seems fine at 14V, also AC on 30 mV - this problem started to appear after a bad battery had to be jump-started many times (brand new battery now) - car seldomly shuts down in low speed (like 1st gear) after driving in highway speeds - got these codes from stores: U1417 Implausible Left Wheel Distance Signal Received P0501 Vehicle Speed Sensor 1 Performance *Plus my reader*: U1412: Implausible Vehicle Speed Signal Received Thank you brothers for any ideas, I'm desperate. Quote Link to comment Share on other sites More sharing options...
larryl Posted May 18, 2024 Report Share Posted May 18, 2024 Is that not the odometer that you have circled? Quote Link to comment Share on other sites More sharing options...
Patoriku Posted May 19, 2024 Author Report Share Posted May 19, 2024 Odometer is on the right (not showing on pic) Circled items are not working ABS light, track control, exclamation mark. Quote Link to comment Share on other sites More sharing options...
Dean H Posted May 19, 2024 Report Share Posted May 19, 2024 (edited) First thing. You need to find a shop or someone with a scan tool. That has the capabilities to read modules and can activate and test individual components. Simple code readers are basically a digital reference. Dean Edited May 19, 2024 by Dean H larryl and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
Patoriku Posted May 19, 2024 Author Report Share Posted May 19, 2024 From ABS module: C100A Left Front Wheel Speed Sensor Circuit C1015 Right Front Wheel Speed Sensor Circuit C1020 Left Rear Wheel Speed Sensor Circuit C2204 Dynamics Sensor Internal Fault C1032 Right Rear Wheel Speed Sensor Signal Erratic Performance C1000 Brake Pedal Switch 1 Circuit Performance C1044 Right Rear Tone Wheel Performance C102B Right Rear Wheel Speed Sensor Circuit Thank you for the reply, yes I got these codes as well. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted May 21, 2024 Report Share Posted May 21, 2024 Use Waze or a gps for speedo until you figure it out. Fairly accurate. Look for wire harness damage, critters could have chewed a connection. It’s a lot of codes at once. Quote Link to comment Share on other sites More sharing options...
