Manually put auto trans in neutral.
Dean H
In a emergency situation, when you need to put the automatic transmission in neutral.
1) open the console armrest.
   Inside by the usb- aux port.
   There is a square tab, that
   pops out. Mine is silver in
   the picture. Hard to see             black.
2) using a flat screwdriver,            push in through slot.
    See picture 2.
    Until you contact the pink
     lever. You will pry up on it.
     Hold it up and the shifter           can be moved.
Edited by Dean H
