Drive Shaft Removal
cansub
2012 SRX R/T AWD. I have the rear of the drive shaft to the differential carrier removed fine. I've removed the center bearing (bracket) and the 6 x 8mm bolts on the front of the shaft. However, the front of the shaft will not budge. I've tried banging, air chisel etc. Is there some trick to removing it?
  • 11 months later...
Does anyone know the installation specs? Torques for fasteners, center bearing preload procedure, etc?
Or which of the online repair guides is going to actually have this information? Thanks.
