2014 not turning over
Ken F.
I have a 2014 DJ with a 3.6l that suddenly won’t turn over, I’ve tried everything from new battery & negative ground sensor and clean all connections tested all fuses & relays and nothing, when I try to start everything turns on but when it goes click the infotainment screen blank & compass goes blank and 15 seconds later goes click and everything turns back on but no crank.
Could be a bad starter motor or even a seized engine....you stated it SUDDENLY happened.Try getting a socket and breaker bar onto the crank pulley bolt and turn the crankshaft CLOCKWISE and see if it rotates . IF so, then starter or wiring to the starter is next step.
EDIT: Also try in Neutral after being sure it is FULLY in the PARK position.
Edited by 5rebel9
