(2014 3.6 awd)Replaced Rockers and lifters, 1st start I got a clunk, now nothing, no crank no codes
2014 dodge journey 3.6 awd
Spent the last couple days tearing down the wifes car, replced the oil filter housing and the Rockers and lifters. Buttoned everything up today and go to start and I get a "clunk" sound and than nothing.  No codes and no crank...
It almost sounded as if the started engaged than backed off...not for sure.
Gonna go back in tomorrow but was wondering if anyone's got anything I should check before tearing it all down again.
Thanks in advance!
Edited by tyeayo
  • tyeayo changed the title to (2014 3.6 awd)Replaced Rockers and lifters, 1st start I got a clunk, now nothing, no crank no codes
Can you turn over engine if you put a ratchet on crank pulley?
What is the battery voltage. If it can be manually turned over and battery is low, try jump starting it.
Push button is fussy on voltage, battery must be in decent shape.
I will give that a try and report back!
I'm worried one of the Rockers came loose and jammed up the camshaft or something...it was a clunk sound and nothing, no engine turnover or anything...very strange
