chrisl Posted June 17 Report Share Posted June 17 I think my car is running too hot it's a 2016 Dodge journey but the heating temperature runs up to 215 to 220 is that normal Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 18 Report Share Posted June 18 So which engine??? Also how many miles on it, might need to do a coolant replacement along with a thermostat replacement...... if 3.6 mine runs from 200 to 215 depending on the heat and how fast I am driving or stuck in traffic,,,,had to replace my thermostat on on 2014 a yr or two ago so you might want to do that just as a preventive maintenance........JUST make sure you are using the correct coolant as well Quote Link to comment Share on other sites More sharing options...
Dean H Posted June 19 Report Share Posted June 19 (edited) 2016 3.6 L 62te 130k Your okay. The electric radiator cooling fan. With the AC off. Turns on at 220 f. Turns off at 215 f. Since replacing a stuck open thermostat. Mine runs like this. Dean Edited June 19 by Dean H Quote Link to comment Share on other sites More sharing options...
