mikecast Posted June 19, 2024 Report Share Posted June 19, 2024 I needed to know how many O2 sensors does my 2014 2.4L journey have . I can see (2)behind the engine on the cat as well,but would those be the same size or are two different sensors. Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 20, 2024 Report Share Posted June 20, 2024 (edited) rockauto shows both the same part number...............numbers Google is your friend DENSO 2344547 $30.79 Each Edited June 20, 2024 by 2late4u jkeaton, larryl and John/Horace 3 Quote Link to comment Share on other sites More sharing options...
mikecast Posted June 20, 2024 Author Report Share Posted June 20, 2024 oh k, so it would the same size and number then. thanks 2late4u 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted June 21, 2024 Report Share Posted June 21, 2024 First car I have seen with both the same, cool. NTK who are part of NGK spark plug company make the oem unit. I have had them on a journey for 5 yrs with no issues. Denso also make good products, they are mainly owned by Toyota and are one of the largest auto part companies. Have always had good luck with their products. Quote Link to comment Share on other sites More sharing options...
mikecast Posted June 21, 2024 Author Report Share Posted June 21, 2024 so yes they are the same ..thanks ,we'll be changing em out asap👍🏻 Quote Link to comment Share on other sites More sharing options...
mikecast Posted June 23, 2024 Author Report Share Posted June 23, 2024 can't seem to make em budge... is it still left loose ,me facing the front of my journey 2.4l 2014 se Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted June 23, 2024 Report Share Posted June 23, 2024 On 6/23/2024 at 8:24 PM, mikecast said: can't seem to make em budge... is it still left loose ,me facing the front of my journey 2.4l 2014 se Expand YES ! O2 sensors can get VERY TIGHT from all the heating/cooling cycles of engine operation. I've had to resort to 3' long 1/2" drive breaker bar for a few of the many I've changed thru the years. Make sure you use a quality O2 sensor socket, some designs are better than others. Quote Link to comment Share on other sites More sharing options...
mikecast Posted June 24, 2024 Author Report Share Posted June 24, 2024 ithanks for the tip...I got some walker product that orielys only had on stock at the moment, was able to remove upstream one and connect it as well, but when I started the journey up, it didn't make sense why it was acting all weird with the light flicking inside dash, like if it needed a new battery. just went ahead removed the new O2 sensor and replaced the old back and worked well. why would it do that???still confused Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted June 24, 2024 Report Share Posted June 24, 2024 On 6/24/2024 at 10:03 AM, mikecast said: ithanks for the tip...I got some walker product that orielys only had on stock at the moment, was able to remove upstream one and connect it as well, but when I started the journey up, it didn't make sense why it was acting all weird with the light flicking inside dash, like if it needed a new battery. just went ahead removed the new O2 sensor and replaced the old back and worked well. why would it do that???still confused Expand What brand sensor did you try? OE, Denso and NTK work best. Bosch is not well liked in these motors. How many miles on the car and what symptoms/codes made you decide for O2 sensors? You may have a bad cat converter or other fuel management troubles. 2late4u and larryl 2 Quote Link to comment Share on other sites More sharing options...
