Only 2 vyclonders
Yogitech1
I have a 2010 Dodge Journey SE that suddenly started running only on 2 cylinders. I traced wires with good continuity between the PCM and the coils so I replaced the PCM. The car started right up but, still ran the same. In the old PCM I had codes for the the 2 coils not firing and a throttle actuator code. What would I look at next? Now I also had one of those in intake turbulence enhancer with a plastic blade, well, the blade has disappeared. Where do I look next? Compression is 225 x 4.
