rae723 Posted July 2 Report Share Posted July 2 My 2013 Dodge journey AC is acting up. It was blowing hot on the drivers side. We replaced the blend door Actuator but that didn't help but we also did it ourselves and didn't calibrate it. I read that should happen. Not I notice it's only blowing cold on the front passenger side. Drivers side and all 4 vents in the back are warm Quote Link to comment Share on other sites More sharing options...
John/Horace Posted July 3 Report Share Posted July 3 Calibrate can be bypassed if you power off car. Remove the hvac fuse with continuous power in passenger kick panel, after you have heard hvac cycle itself closed, roughly 3 mins with car off. … and then install the new activator switch. Fuse goes back in again after that. Worked for me on passenger side fresh air recirc actuator. Hvac vents cabin for 90 seconds after every run cycle. Prevents mold/condensation issues, most cars do it. Are you hearing loud clicking from the driver side unit you installed. That would probably indicate it’s in wrong position now. Those switches are a bear to get to. Quote Link to comment Share on other sites More sharing options...
gthegreat1 Posted July 10 Report Share Posted July 10 Maybe you have a leak and need more refrigerant. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 10 Report Share Posted July 10 (edited) nope, blend door problem, I hope when he gets it fixed he will report back on where and which blend door it is for others to use such info Edited July 10 by 2late4u Quote Link to comment Share on other sites More sharing options...
