randos1 Posted July 7, 2024 Report Share Posted July 7, 2024 since it has a timing chain, do you still have to remove the chain to remove the water pump. was thinking of doing this myself, till i watched a video and saw a timing belt had to be removed. mine has a chain Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 7, 2024 Report Share Posted July 7, 2024 3 hours ago, randos1 said: since it has a timing chain, do you still have to remove the chain to remove the water pump. was thinking of doing this myself, till i watched a video and saw a timing belt had to be removed. mine has a chain Watch videos relating to TOUR cars ENGINE SIZE the 3.5 is a different engine altogether from the 3.6. NO there is NO CHAIN REMOVAL for doing a 3.6 engine water pump, just the serpentine drive belt. larryl and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted July 9, 2024 Report Share Posted July 9, 2024 Water pump change on 3.6 requires working threw passenger wheel well. Motor mount needs to be removed and engine supported with a jack stand. A decent torque wrench needs to be used on aluminum engine work like this. Replace the plastic housing with thermostat/bleed screw ($20 item) while doing this job. Use a new pump, not a reman unit. If you struggle with brake jobs…stay away from doing this repair on a daily driver. Free advice worth everything you pay for it. jkeaton and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
