richard033 Posted July 15, 2024 Report Share Posted July 15, 2024 Hello all. My ECU died a few months ago and i could get a replacemnt ECU from flagship one, they programed it using the numbers on the old ECU (took pictures and mailed it to them) the mechanic installed it today Now the engine turns over but it won't start. We are out of idea's. Does anyone have something we could try? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted July 16, 2024 Report Share Posted July 16, 2024 Milage on car, engine size ? How did you test an ecm yourself, you must have a very high end scanner. Crank no start causes is a very long list. Trouble shoot via codes is always the starting point. Only cheap wear item that can cause no start and not always trigger code is CPS crank position sensor. OEM are around $30 us. Common 2.4 engine issue, heat vibration wear them out eventually, often by 100k. If it’s a programmed chip key, try the other key. larryl 1 Quote Link to comment Share on other sites More sharing options...
richard033 Posted July 19, 2024 Author Report Share Posted July 19, 2024 Milage on car, engine size ? How did you test an ecm yourself, you must have a very high end scanner. 148.000 KM 2.4l, car is at the mechanic and he wil test the ECM and read the error codes Crank no start causes is a very long list. Trouble shoot via codes is always the starting point. Only cheap wear item that can cause no start and not always trigger code is CPS crank position sensor. OEM are around $30 us. Common 2.4 engine issue, heat vibration wear them out eventually, often by 100k. If it’s a programmed chip key, try the other key. No go! Tjank for the tips! Quote Link to comment Share on other sites More sharing options...
