5rebel9 Posted Sunday at 07:33 PM Report Share Posted Sunday at 07:33 PM (edited) 43 minutes ago, 2late4u said: no mention if one of the wheels have been hit or bent, I had a brand new journey 2011 came with a vibration ,I tracked it down to one of the rim,s dealer replaced it and fixed the problem I kept rotating front to rear in different variations on the wheels till the vib was almost gone then took it to the dealership and told them what I had done and that the bad rim was one of the rears, they figured out which one and looking at it you couldn't tell just bad from the manufacture You may be on to something here! I took the OP's word on multiple balancings being done and should have revealed a bad rim situation IF the person doing the task watched the tire AND wheel spin. One would not expect to see a bad aluminum rim unless a very noticeable bend from say a curb hit or severe pothole. I did countless tire changes and balances in my day and always watched how the tire and rim for "wobbling" as they spun in the balancer. Also an unusual amount of weight being needed to bring a tire "into balance" should be another "tip off" to a tire or rim problem. My standard was anything over 4 ounces on a passenger car tire was cause for further investigation. My apologies to our metric standard members for not giving the metric equivalent, but I think you will understand the "gist" of my posting. Edited Sunday at 07:35 PM by 5rebel9 2late4u 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted 23 hours ago Report Share Posted 23 hours ago Some of us grew up on imperial and were made to switch in grade school, when feds brought in metric. I still keep house thermostat in Fahrenheit, finer adjustment. The calculator on our smart phones is great for converting, so 4 ounces is 113 grams. Yeah hate seeing huge weights on a tire. Tire with largest weight usually goes driver rear, farthest from steering wheel. Most weights double marked, here is pick of a 1oz or 28 gram and a 1.5 oz or 43 gram. Four oz would be huge, around 4 inches, but I have seen them used. Quote Link to comment Share on other sites More sharing options...
steve lada Posted 22 hours ago Report Share Posted 22 hours ago 10 hours ago, John/Horace said: Sounds like a frustrating problem, at least the stuff you have changed out are wear items. If you keep the car you are ahead. You could paint mark all flange connections where driveshaft bolts up; then index the flanges and bolt together again. Or if you have the old shaft you could try reinstalling it. But before reinstalling another driveshaft try driving the vehicle up to vibration speed. If it’s gone you at least have the source. Driving without shaft may trigger a dash light, some people unplug the connector feeding the rear diff. It’s the coil power source for engaging awd. When changing drive shafts mechanics usually mark current location. But with a new shaft it’s not an option. Some shops do have special vibration analysis tools for trouble shooting tricky problems. I do not have the old drive shaft. the carrier bearing was clearly worn and rusted, and i was certain this problem was solved. not to be...now the mention of shops having a special analysis tool has my attention. I have never heard of such a thing but my eye balls are wide open. my 2015 is soon to be a 2025..............would love to find this to help another guy. I was even gonna go back to the mechanics shop and fill him in in case he ever had one like this. its probably gonna cost me more than the damn thing is worth....but now ..I'm pissed. Quote Link to comment Share on other sites More sharing options...
steve lada Posted 11 hours ago Report Share Posted 11 hours ago you are right about one thing,most are wear parts. so my 2015 is almost a 2025! all of the wheels have been checked many times on a high speed balance machine. John,are you saying try driving without the driveshaft connected? hmmmmmm and letting the front wheel drive take over??? I never would have thought of this. but can this really be done? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted 6 hours ago Report Share Posted 6 hours ago (edited) 5 hours ago, steve lada said: you are right about one thing,most are wear parts. so my 2015 is almost a 2025! all of the wheels have been checked many times on a high speed balance machine. John,are you saying try driving without the driveshaft connected? hmmmmmm and letting the front wheel drive take over??? I never would have thought of this. but can this really be done? Yes it has been done by several people on the site for trouble shooting. Safe, doesnt hurt anything. This facebook link to Royalty Auto Surface(good info site) shows chasis vibration sensors locating problem. Not all shops have this equipment. When I worked as a millwright mechanic before retiring, we had vibration analysis tools. https://www.facebook.com/share/v/1FTMQhM1NF/ 5 hours ago, steve lada said: Edited 6 hours ago by John/Horace Quote Link to comment Share on other sites More sharing options...
2late4u Posted 4 hours ago Report Share Posted 4 hours ago NOT on a dodge journey but the same process to see if your problem is rear end related also this has been discussed here in the forum quite a bit on driving without the awd shaft installed you tube is full of a lot of info check it out Quote Link to comment Share on other sites More sharing options...
2late4u Posted 4 hours ago Report Share Posted 4 hours ago you mentioned........ There was a small impact in aft RH wheel (you can see attached photo) but everything in the rear suspension has been replaced including the shock absorber with new parts. Balancing of all wheels done. All mentioned below parts are new as well: All brake rotors plus servicing of the calipers. Rear RH and front LH wheel hub/bearing Rear RH drive shaft so was the wheel bearing on which this damaged rim was replaced as well???? I see you said it was the same feeling with the 19 inch rims and the 17 inch rims as well that is why I am asking about the wheel bearing ..........good luck Quote Link to comment Share on other sites More sharing options...
