Scode68 Posted January 6, 2011 Report Share Posted January 6, 2011 Is there some kind of special procedure to back or the rear caliper pistons due to the way the parking brake is? Not up on these Doge cars but shouldn't I be able to just use a large C-clamp to back the piston off so that I can install new pads? Maybe they are frozen? The piston looks like it is aluminum and not phenolic like the front pistons. This could be part of the reason behind replacing the front rotors and pads. Quote Link to comment Share on other sites More sharing options...
larryl Posted January 6, 2011 Report Share Posted January 6, 2011 you need a tool to back off the rear calipers Quote Link to comment Share on other sites More sharing options...
Scode68 Posted January 7, 2011 Author Report Share Posted January 7, 2011 On 1/6/2011 at 10:11 PM, larryl said: you need a tool to back off the rear calipers thanks, Didn't have a tool to fit so I just carefully used a pair of needle nose pliers. Quote Link to comment Share on other sites More sharing options...
Acerx12 Posted April 10, 2011 Report Share Posted April 10, 2011 Yes needle nose will work. I used a caliber bolt to place in the pliers and it properly spaces the ends of the ends of the pliers to the correct distance of the piston slots. Quote Link to comment Share on other sites More sharing options...
