Locosiete Posted July 21 Report Share Posted July 21 (edited) Never really felt like the rear window had great visibility and then after adding a small sound system it reduced the view slightly more. Since i have a small obstruction blocking my view out the rear window thought why not remove the rear wiper and put in a camera. Process was pretty easy for the most part. Removed the 2 screws and popped the clips out. By no surprise the rear wiper motor screws holding it together were loose from a small vibration i have 😆 😅 😂 Used cut the rear wiper grommet out for camera and mounted it upside down to reduce angle of camera. While not a perfect solution it does allow me to see much better when backing up since rear view mirror is not very helpful anymore 😆 😅 😀 😄 Edited July 21 by Locosiete typo 5rebel9 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 21 Report Share Posted July 21 VERY INTERESTING! One question, did you already have a backup camera wired thru the car or did you have to do that also? My friend says I can come and take camera and any needed wiring from one of his parts carts for the wifes '13 RT {big screen radio} and equipped with back up SENSORS that show in the EVIC screen between the gauges. I get so little down time with that car that it's hard to take things apart just to see what I may need. Of course I'll be using the factory mount location. Locosiete 1 Quote Link to comment Share on other sites More sharing options...
Locosiete Posted July 21 Author Report Share Posted July 21 (edited) I had previously installed a backup camera in-between the license plate lights. Worked fine for backing up but rather see behind me in general. I tucked the wire between the Headliner and door seal and ran it down the a-pillar. Hardest part was trying to fish the wire in the rubber grommet at the rear gate. At the end made a small hole at base of grommet and wire is outside the rubber sleeve I should add the new camera had different plug so had to run wire again. Just taped new end to old and used it to fish it threw Edited July 21 by Locosiete add info Quote Link to comment Share on other sites More sharing options...
