Salah-Belkhodja Abdeslem Posted July 29 Report Share Posted July 29 hi , i need your opinion please, my two reverse light are not working since few days , the bulbs has been replaced and the fuse is good . Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 29 Report Share Posted July 29 you probably have a broken wire in or near the left upper rubber boot on your hatchback. common problem on older journeys due to thin wires check out YouTube for more info or look Thur the forums section under the Electrical, Battery & Charging tab good luck and report back on what you find to be your problem....also checking at the light itself IF you are getting any juice with a meter larryl 1 Quote Link to comment Share on other sites More sharing options...
Salah-Belkhodja Abdeslem Posted July 29 Author Report Share Posted July 29 thanks a lot i'll do that as soon a s possible , and i'll give a feed back Quote Link to comment Share on other sites More sharing options...
Salah-Belkhodja Abdeslem Posted July 30 Author Report Share Posted July 30 (edited) it was exactely as you said , a white (green) wire was cut in the tailgate sheath. many thanks for your fast help. the reverse lights are back in service. Edited July 30 by Salah-Belkhodja Abdeslem 2late4u and larryl 1 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 30 Report Share Posted July 30 take some time and read thru the forum for a lot of GREAT and some bad advise,,take care larryl 1 Quote Link to comment Share on other sites More sharing options...
