2018 dodge journey 2.4L po562
So recently my starter went out on my 2018 2.4l i had it replaced and it cranked a few times without any problems then went down to taking about 10 times to get it started with a small crank and a small turn over then finally turned over and im getting a c212A-16 (low abs system voltage) error code Aswell. the car is 97k miles and taken care of and has not given me a problem until now and it keeps doing random things once then fixing itself when i turn it off turn it back on (blowing cold air on the driver side then hot air on the passenger. radio not working, flashing abs lights and traction control lights on and off) and when i start it it idles high and is almost bogging, resting at about 1.5k any ideas?
so all the problems started after the replacement of the starter? that is where I would start looking for your problems might be as easy as a bad or one that is loose, could be wires going to the starter shorting out as well, did you replace the starter or did you have a shop do it? to many things going wrong at the same time right after the starter install. might want to have them recheck what they did?  also have your BATTERY load checked and also the alternator checked out at your local part stores and they can even check the starter out as well at least that is a free check as well good luck and please report back on what you find out to be the problem for others to learn from   also how old is your battery? OEM? good clean and tight connections? also check the battery jump connectors up top of the engine as who ever might have disconnected it there from the battery during the starter install and didn't tighten them back up,you would be surprised people come here asking about electrical problems and then come back and say it was a loose battery connection,or dirty ,or a almost bad battery do the free cheap check first before using the parts cannon...P.S. Welcome to the group as well
Edited by 2late4u
