Frex Posted August 15, 2024 Report Share Posted August 15, 2024 I have a 2016 3.6L FWD Journey with 107K miles. I have a receipt of work done that said the transmission fluid was changed at 62K, however, I cannot confirm it. It was done at a Tires Plus and when I called there they said they typically don't change transmission fluid. (I'm thinking it maybe the old charge for something and not do it, but I have no idea.) In any event, while replacing my radiator I did not seat the trans cooler lines properly and they blew off. I had the car towed and had the lines properly seated and had about approximately 5 quarts of trans fluid placed back into the car. The car drives fine expect for a minor tick with the first gear change of the day, which may have always been there but I notice now because of being hyper sensitive with the transmission. I know the manual says to change the trans fluid at 120K. Do you guys think I should have it changed at 120K given I had 5 new quarts put in when I lost the trans cooler lines? I did nothing with the filter or anything else- just replaced the lost transmission fluid. Quote Link to comment Share on other sites More sharing options...
Dean H Posted August 15, 2024 Report Share Posted August 15, 2024 (edited) Based on my experience and what I have learned. I feel the minimum service would be fluid and filter change at 60k miles. Personally, I feel doing a transmission flush is an expensive gamble. Everything,I know is posted here. https://www.dodgejourneyforum.com/topic/18151-automatic-transmission-fyi-please-read/ Edited August 15, 2024 by Dean H Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 15, 2024 Report Share Posted August 15, 2024 Had mine ( 2014 crossroad)done at the dealership at around 60 k and then had it done again at around 100 k when i had my plugs and coolant service done as well not cheap at the dealership but i have the lifetime warranty so i wanted it on record that they had done it...I wouldn't rec anyone to do a flush Quote Link to comment Share on other sites More sharing options...
