Intermittent P0394 code, very weird
Jmoseley336
2016 DJ service CD.
Excuse the all caps text. That is how it copied over from a picture.
Code set conditions -
At least five seconds or 2.5 engine revolutions have elapsed with Crankshaft Position Sensor signals present, but no camshaft position sensor signal.
Possible causes -
5-VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE
5-VOLT SUPPLY CIRCUIT OPEN
5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
5-VOLT SUPPLY CIRCUIT SHORTED TO THE SENSOR GROUND CIRCUIT
CMP 2/2 SIGNAL CIRCUIT SHORTED TO VOLTAGE
CMP 2/2 SIGNAL CIRCUIT SHORTED TO GROUND
CMP 2/2 SIGNAL CIRCUIT SHORTED TO THE SENSOR GROUND CIRCUIT
CMP 2/2 SIGNAL CIRCUIT OPEN/HIGH RESISTANCE
SENSOR GROUND CIRCUIT OPEN/HIGH RESISTANCE
CAMSHAFT POSITION SENSOR 2
TONE WHEEL LOOSE OR DAMAGED
POWERTRAIN CONTROL MODULE (PCM)
18 hours ago, Dean H said:
2016 DJ service CD.
Possible causes -
Yeah I'm aware of the procedure, but thank you though!
9 minutes ago, John/Horace said:
Milage on vehicle, any recent work done on it.  AWD or two wheel drive vehicle? Parked in a garage or outside with the rodents ?
About 187,575 and only thing done recently is timing chain, oil pump and oil cooler. It's parked outside but the wiring still looks good as far as I can see, the code comes on very randomly. Sometimes I can drive hours with no code and sometimes it comes on it under 30 minutes
Sensor for bank 1 and 2 are the same. YES have to pull the upper intake off to R&R them. rockauto price is relatively inexpensive, and at that mileage would not be a bad idea to replace both. Like any high mileage sensor that gets hit with oil all the time, a small crack can happen that lets oil get inside and "knock out" sensor reading. I had this happen with the crank sensor on my '13 3.6 AWD.....not so easy to replace as the CMP sensors.
I've already changed both cam sensors on each bank with known verified good ones from my 13 Chrysler 300 3.6 and still getting the same thing, but I have not changed the crankshaft position sensor because no codes for it, I only have one code and it's the p0394, what code were you getting that caused you to change the crankshaft position sensor?
Also changed vvt solenoids with no change
Why not try giving full info as to what has been done to prevent already done that responses. I had intermittent engine shut downs and jerking and FINALLY threw code P0339 for crank sensor. On inspection of removed sensor, the electrical plug end was full of oil. I posted of this SOMEWHERE on the forum some time ago.
If you say so much plug and play has been done, then it comes down to "shooting" wire readings between sensor and ECM. Service manual/wire schematics for your year are posted here on the forum for folks to look up to help diagnose your problem.
EDIT : I think you are mistaking the ones on the passenger side for the 2{1 on each Valve cover} on the drivers side{trannie side}
Edited by 5rebel9
You're right, that was my mistake. And I don't just say, they have in fact been changed with known good ones. And I changed out both camshaft sensors just to be safe on bank 1 and bank 2.
A bit of work to do, but if you did change those 2 sensors with used ones. Try swapping location and see if code changes{ for bank position}, then you will know if indeed it is the sensor and not further involved.
Edited by 5rebel9
  • 3 weeks later...
On 8/15/2024 at 2:13 PM, Jmoseley336 said:
As the title States I have a intermittent po394 code that randomly shows up, sometimes I can drive for a day or two without it coming on. Timing is perfect, already tightened the bolts behind the VVT solenoids etc. Where should I look now?
Reset pcm and tcm. Just make sure you pull every fuse that's labeled pcm or tcm.
So far; I've did oil galley bolts, triple quadruple checked that timing is perfect, all components are less than a month old so I know all is well there including oil pump, switched Camshaft, cam phaser and oil control valve with all known good parts. I'm truly at lost, I've never fought a vehicle this long. I did notice once it goes into limp mode Intake Cam 2/ Crank difference gets stuck at 42.0, a simple reset of the car and it's back to reading normal/drive absolutely perfect until the code is set and limp mode happens again.
