tdottrucker Posted August 16 Report Share Posted August 16 (edited) I have a 2016 RT with the 3.6. If I step on the gas off of a light, i will hear a faint metallic rattle that is very fast in sound occur as the vehicle gets to around 2100 and stops by 2500 rpm as the vehicle shifts. if I lightly step on the gas and slowly accelerate to a gear change, no noise will happen, but only on more average to aggressive accelerations. In Neutral or park, I will hear this sound if I aggressively step on the gas and the RPM passes through 2500-2700rpm, but will not happen if I slowly press the gas and accelerate beyond 3000rpm. I’m trying to find out what is making this sound. I know I have a loose heat shield that makes a dinging sound while moving forward (verified it, just need to retighten it). But this sounds a little different. ** I can try to get a video of the sound if this would help identify the problem. Edited August 16 by tdottrucker Quote Link to comment Share on other sites More sharing options...
John/Horace Posted August 18 Report Share Posted August 18 Milage on car. Any recent work completed? Could be anything spinning on the engine. Remove surpentine belt and only for a min or two (water pump won’t be running) run the engine and listen for the sound. Report back. Engine stethoscope are about $10 at Princess Auto/Harbour Freight. Very good for trouble shooting noises. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
tdottrucker Posted August 18 Author Report Share Posted August 18 153,000 kilometres with no recent work other then RF Hub replacement for RKE issues that are unresolved still. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted August 18 Report Share Posted August 18 Just a guess as there are a number of heat shields under our rides. But possibly a cat converter heat shied coming apart? Quote Link to comment Share on other sites More sharing options...
