black09SXT Posted January 10, 2011 Report Share Posted January 10, 2011 Just recently, the passenger side light bulb for the HVAC controls, like the passenger side temperature knob and air direction selector buttons went out. The drivers side temperature knob and blower speed are still working. My question is if anyone has a guide to the type of miniature bulb replaces it without having to dig into the dash first? I know most all local parts stores do not carry these types of bulbs and I will have to order them online, but I was just curious on if anyone knew the part number to this bulb. Thanks. Quote Link to comment Share on other sites More sharing options...
FleshWound Posted January 11, 2011 Report Share Posted January 11, 2011 On 1/10/2011 at 10:18 AM, black09SXT said: Just recently, the passenger side light bulb for the HVAC controls, like the passenger side temperature knob and air direction selector buttons went out. The drivers side temperature knob and blower speed are still working. My question is if anyone has a guide to the type of miniature bulb replaces it without having to dig into the dash first? I know most all local parts stores do not carry these types of bulbs and I will have to order them online, but I was just curious on if anyone knew the part number to this bulb. Thanks. REPLACEMENT BULBS All the inside bulbs are brass or glass wedge base. Aluminum base bulbs are not approved and should not be used for replacement. LIGHT BULBS – Interior Bulb Number Courtesy/Reading Lamps (Incandescent) 578 Courtesy/Reading Lamps (Optional LED) LED (Serviced at Authorized Dealer) Glove Box Lamp 194 Cargo Lamp 579 Optional Door Map Pocket/Cupholder LED (Serviced at Authorized Dealer) Note: For lighted switches, see your authorized dealer for replacement instructions. LIGHTS BULBS – Exterior Bulb No. Low Beam Headlamp 9006 High Beam Headlamp 9005 Front Park/Turn Signal 3757AK Side Marker Lamp 168 Front Fog Lamp PSX24W Center High Mounted Stop Lamp (CHMSL) LED (Serviced at Authorized Dealer) Rear Tail/Stop/Turn Signal 3157K Rear Tail 3157K Backup Lamp 3157K License Lamp 168 SORRY this is all i could find until someone releases an electronic service manual Quote Link to comment Share on other sites More sharing options...
OhareFred Posted January 12, 2011 Report Share Posted January 12, 2011 On 1/10/2011 at 10:18 AM, black09SXT said: Just recently, the passenger side light bulb for the HVAC controls, like the passenger side temperature knob and air direction selector buttons went out. The drivers side temperature knob and blower speed are still working. My question is if anyone has a guide to the type of miniature bulb replaces it without having to dig into the dash first? I know most all local parts stores do not carry these types of bulbs and I will have to order them online, but I was just curious on if anyone knew the part number to this bulb. Thanks. Is the display out, or is the back lighting when the headlamps are turned on out? In other words, can you see anything at all on the passenger side at any time? If you can't see anything, sorry it's not a replaceable bulb, its the display. You'll need to go to the dealer to fix it, or, if you are handy, you might be able to find a new control head on the internet. Thats what you need, not a bulb. Sorry! Quote Link to comment Share on other sites More sharing options...
steak Posted January 12, 2011 Report Share Posted January 12, 2011 Are you under waranty? if you are, take it in. do you have Manual or Auto climate control? Those bulbs does NOT have part number, they are soldered onto the Circuit board. if you are going to replace the whole control, i think they are like $150 list price from the dealership. The Center bezel can be removed by a trim stick, or just yank it out by hand, they are just held on by clips. I've taken it apart and soldered new bulbs onto the circuit board, and it works. So if you got some practice on fixing circuit boards in TV or VCR players, go for it. if you want to know what type of bulbs i used, i have no idea. I just took few same size bulb from the bulbs bin in my dealership. Quote Link to comment Share on other sites More sharing options...
jim125us Posted March 4, 2011 Report Share Posted March 4, 2011 ok on the 2008 aspen the atc bulbs are also not replaceable at least by a part number but my dealer sold me bulbs thinking these were the needed ones. they are the same bulbs needed but the base is a very little bit smaller and wont twist into the control head. but they are twist in not soldered. im going to try to use the bulb they sold me into the old base because the new control head is 350.00. I cant believe they have no lamps avail for this. not very good. Quote Link to comment Share on other sites More sharing options...
