RPDalton Posted August 22, 2024 Report Share Posted August 22, 2024 I have a 2017 Dodge Journey with the 2.4L engine. The engine is seized and does not rotate. Does the entire engine and transmission come out the top or the bottom so I can split them apart? With the engine not being able to rotate, I cannot access the torque converter bolts to split them and just pull the engine. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted August 22, 2024 Report Share Posted August 22, 2024 On 8/22/2024 at 9:32 AM, RPDalton said: I have a 2017 Dodge Journey with the 2.4L engine. The engine is seized and does not rotate. Does the entire engine and transmission come out the top or the bottom so I can split them apart? With the engine not being able to rotate, I cannot access the torque converter bolts to split them and just pull the engine. Expand Sorry to hear of a siexed motor. Although it may seem like more steeps to do, it's far easier and less nerve wracking to drop it out the bottom. Either way, not a fun job.Good Luck and keep us posted as to how things go. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
RPDalton Posted August 23, 2024 Author Report Share Posted August 23, 2024 It is unfortunate. The owner simply never checked the oil. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted August 24, 2024 Report Share Posted August 24, 2024 Maybe drop the oil pan and unbolt connecting rods. Could allow crank to turn again. larryl 1 Quote Link to comment Share on other sites More sharing options...
RPDalton Posted August 27, 2024 Author Report Share Posted August 27, 2024 That exactly what I did. Pulled the pan, unbolted a few rod caps and got it to rotate. John/Horace 1 Quote Link to comment Share on other sites More sharing options...
