Puffy Posted August 24, 2024 Report Share Posted August 24, 2024 I'm sorry,but I couldn't find a similar question.When I'm stopped when I turn the steering wheel left it makes ONE popping noise.Please help. Quote Link to comment Share on other sites More sharing options...
larryl Posted August 25, 2024 Report Share Posted August 25, 2024 Clockspring broken 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Puffy Posted August 25, 2024 Author Report Share Posted August 25, 2024 Sorry I wasn't more clear Larry,but this popping is not in the steering column,it's deeper in the steering somewhere. Quote Link to comment Share on other sites More sharing options...
Dean H Posted August 26, 2024 Report Share Posted August 26, 2024 Dodge 2016 service chart Steering POPPING NOISE 1. Loose steering gear mounting fasteners. 2. Loose outer tie rod mounting nut or jam nut. 3. Loose intermediate (steering) shaft coupling at gear input shaft. 4. Worn tie rod (outer or inner). 5 Worn axle half-shaft. Corrective actions - 1. Check fasteners for proper torque and retighten as necessary. 2. Check fastener torque. Replace nuts as necessary and tighten to specifications. 3. Make sure coupling is fully seated on gear input shaft. Retighten or re-seat as necessary. 4. Inspect 5. inspect 2late4u and larryl 2 Quote Link to comment Share on other sites More sharing options...
larryl Posted August 26, 2024 Report Share Posted August 26, 2024 ^^^ that pretty much covers it 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Puffy Posted August 27, 2024 Author Report Share Posted August 27, 2024 Thank ya'll VERY much for your help! Quote Link to comment Share on other sites More sharing options...
