BGL Posted January 13, 2011 Report Share Posted January 13, 2011 Can the remote start function be programmed to turn on the heated seats when starting the vehicle? Quote Link to comment Share on other sites More sharing options...
FleshWound Posted January 13, 2011 Report Share Posted January 13, 2011 Can the remote start function be programmed to turn on the heated seats when starting the vehicle? the idea has been discussed on other forums I frequent, but to my knowledge it hasn't been acheived. Quote Link to comment Share on other sites More sharing options...
geurny2011 Posted March 27, 2011 Report Share Posted March 27, 2011 You have the option of turning them- on/off, hi/low( on start up ) from the options menu on the uconnect screen. Hope this helps. Quote Link to comment Share on other sites More sharing options...
drb227 Posted March 28, 2011 Report Share Posted March 28, 2011 To clarify: With the 8.4/8.4N system, under the settings menu, there is an option called Auto-on Comfort and Remote Start. Under that option, there is an option called Auto-on Driver Heated/Ventilated Seat & Steering Wheel with Vehicle Start. When you enable this setting, the heated driver's seat will always turn on to the high setting whenever you start the vehicle normally or with remote start, as long as the outside temp is below 40 degrees F or 4.4 degrees C. Note that we only have the heated seat, no ventilated seat or heated steering wheel. It is just a common option name since this system is also available for the 2011 Charger and 2011 300. Quote Link to comment Share on other sites More sharing options...
Myredjourney Posted April 1, 2011 Report Share Posted April 1, 2011 I've been wondering about that. I programmed mine for the heated seats to come on when I use the remote start but the seat didn't seem to be heated when I went out. I've only had it a week and maybe the outside temp was above 40F. No one ever mentioned that the temperature played a part. Quote Link to comment Share on other sites More sharing options...
GRF Posted April 20, 2011 Report Share Posted April 20, 2011 Can the remote start function be programmed to turn on the heated seats when starting the vehicle? IF YOU READ THAT BIG BOOK WE ALL HAVE.....YOU CAN ONLY START THE ENGINE AND STOP IT...MAY BE YOU'LL FIND SOME INFORMATION ON LINE........ Quote Link to comment Share on other sites More sharing options...
Draver17 Posted July 13, 2011 Report Share Posted July 13, 2011 To clarify: With the 8.4/8.4N system, under the settings menu, there is an option called Auto-on Comfort and Remote Start. Under that option, there is an option called Auto-on Driver Heated/Ventilated Seat & Steering Wheel with Vehicle Start. When you enable this setting, the heated driver's seat will always turn on to the high setting whenever you start the vehicle normally or with remote start, as long as the outside temp is below 40 degrees F or 4.4 degrees C. Note that we only have the heated seat, no ventilated seat or heated steering wheel. It is just a common option name since this system is also available for the 2011 Charger and 2011 300. it's also on by default Quote Link to comment Share on other sites More sharing options...
tankclark9 Posted October 1, 2011 Report Share Posted October 1, 2011 I have a 2011 journey crew and the heat does not come on with the remote starter or does the radio but as soon as you open the door it come on. Took it to the dealer they tried a couple of other journey on the lot and all the same problem. Quote Link to comment Share on other sites More sharing options...
Windancer Posted October 13, 2011 Report Share Posted October 13, 2011 With the 8.4/8.4N system, under the settings menu, there is an option called Auto-on Comfort and Remote Start. Under that option, there is an option called Auto-on Driver Heated/Ventilated Seat & Steering Wheel with Vehicle Start. When you enable this setting, the heated driver's seat will always turn on to the high setting whenever you start the vehicle normally or with remote start, as long as the outside temp is below 40 degrees F or 4.4 degrees C. Wish my 2010 had that option Terry Quote Link to comment Share on other sites More sharing options...
19InBlkJrny Posted October 13, 2011 Report Share Posted October 13, 2011 Windance This off topic, but do you have the REU mygig in your 2010? If so I'd like to ask you a few questions about it. Omar Quote Link to comment Share on other sites More sharing options...
drozz Posted October 14, 2011 Report Share Posted October 14, 2011 The feature does work on my 2011 Crew. We got ours in march of this year while it was still cold out in the mornings. When i use the remote start and it was cold out, the heated seats came on. Quote Link to comment Share on other sites More sharing options...
Windancer Posted October 24, 2011 Report Share Posted October 24, 2011 (edited) This off topic, but do you have the REU mygig in your 2010? If so I'd like to ask you a few questions about it. I'm not sure which radio I have, will look on the way home. I just checked it is a REU Media Center 830N Terry Edited October 24, 2011 by Windancer Quote Link to comment Share on other sites More sharing options...
19InBlkJrny Posted October 25, 2011 Report Share Posted October 25, 2011 I'm not sure which radio I have, will look on the way home. I just checked it is a REU Media Center 830N Terry Terry Thanks for the reply. I already learned what I needed to know about the REU. I wanted to swap my REN for the REU for the 6 disk changer, but I found out that I can't control an Ipod with the REU. Now I have to decide which is more important, Ipod control or getting rid of the stash of barbie and strawbery short cake DVD boxes all over my car. (I have two girls that love the VES) Omar Quote Link to comment Share on other sites More sharing options...
