mpisio Posted Sunday at 05:29 PM Report Share Posted Sunday at 05:29 PM I want to replace the positive and negative cables, running from the battery, and into the engine compartment. I know I could remove them and measure, but this is my only vehicle, and I don’t want to do a remove - replace - remove - install. I’d much rather do a remove old - install new type of thing. Any and all help will be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Dean H Posted Sunday at 08:17 PM Report Share Posted Sunday at 08:17 PM (edited) You have 2010 Journey? My 2016 DJ is different than yours regarding cable connections. Post a picture of driver's side strut tower. Where the negative battery cable connects. I believe the battery positive cable connects on the strut tower, as well. Edited Sunday at 08:17 PM by Dean H Quote Link to comment Share on other sites More sharing options...
Dean H Posted Monday at 09:32 PM Report Share Posted Monday at 09:32 PM (edited) I looked up the battery cables for the 2010 DJ. 2.4 and 3.5 engines. The ground cable is separate. Simple to replace go standard 2 AWG cable. Critical factor - The positive cables you need to see how they connect inside the plastic connectors. If you do have this cable arrangement. Get the best pictures of the red cable inside the plastic connectors. See if it is lug ends connected to a bolt. You could put a set together. Complete stock cable harness starts at $155.00. Edited Monday at 09:42 PM by Dean H Quote Link to comment Share on other sites More sharing options...
