2010 Journey with P0760 solenoid C fail code
MXJourney
HI all, I have a 2010 Journey with a P0760, solenoid C fail code. I have done the following.
-measure the resistance across the solenoids, = 1.8 ohms across each solenoid
-measured the resistance on the wires from the solenoid wire connector to the PCM connector, = none
-inspected the wire harness between solenoid connector and PCM connector = no cracked wires, no rubbed or chaffed wiring
-cleaned the grounds, 2 by the PCM and engine ground
-cleaned battery terminals and connectors
After clearing the code, turning the ignition to off and then starting the engine, the error code shows up within a minute or 2.
Is there anything else I should try?   At this point I say it is the PCM that is faulty.
Any advice is welcome.
Mex Hart
