Dilshod NIyozov Posted September 23, 2024 Report Share Posted September 23, 2024 When I lock using the key fob, only the driver door locks. I have to lock each other door manually. However, when I unlock using the key fob, all doors unlock fine. I am not sure what the issue is. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted September 23, 2024 Report Share Posted September 23, 2024 When you state that you "manually" have to lock each of the other doors....Do you mean from the Drivers door ,aster switch or each door individually? Most common fault would be a broken wire in the drivers door to body rubber boot, that all the lock wires run through from the Drivers door master switch. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Dilshod NIyozov Posted September 23, 2024 Author Report Share Posted September 23, 2024 (edited) Each door individually must be locked except the driver door. I checked the wires and didnt see issues there. Maybe i should check again. Note it cant lock but once all doors are locked, it unlocks all doors fine from the key fob. Edited September 23, 2024 by Dilshod NIyozov Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 24, 2024 Report Share Posted September 24, 2024 I am reading that he is using the key fob and they all wont lock but will unlock using the key fob, so I am not sure it would be the wiring in the drivers door be the cause as he is not using the drivers door buttons,might be the key fob signal to the master controller for the door locks where ever that is, more info from the dealership part crib might be a good source of where to start,good luck Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 24, 2024 Report Share Posted September 24, 2024 bcm module wiring seems to be the culprit for some of the problems of doors not wanting to lock and unlock,,over my pay grade of this fix 5rebel9 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted September 24, 2024 Report Share Posted September 24, 2024 13 hours ago, 5rebel9 said: When you state that you "manually" have to lock each of the other doors....Do you mean from the Drivers door ,aster switch or each door individually? Most common fault would be a broken wire in the drivers door to body rubber boot, that all the lock wires run through from the Drivers door master switch. 9 hours ago, 2late4u said: bcm module wiring seems to be the culprit for some of the problems of doors not wanting to lock and unlock,,over my pay grade of this fix Nice video find! But from what I saw was ALLdoor inop in that video. STILL a good one that may help the OP understand what may be going on. Yes, still a probable broken wire somewhere. Nice when you have a high end scanner/tester to isolate and test functions like the video shows. 2late4u and larryl 2 Quote Link to comment Share on other sites More sharing options...
Dean H Posted September 24, 2024 Report Share Posted September 24, 2024 Few questions....... What is the history of the problem? Any vehicle history that may have caused the issue? Has the FOB locked all the doors correctly ever? Does the interior door lock switch lock all the doors? Does the exterior door handle button lock all the doors? Quote Link to comment Share on other sites More sharing options...
