Gammellicious Posted September 27 Report Share Posted September 27 Hello I'm new to the forum and new to dodge journeys. I recently purchased a 2011 3.6 AWD journey and I'm having brake issues. The driver side front brake keeps dragging. Now my traction control light is on and it's in limp mode. I plugged my scanner in and got a U0002-88 for can bus short for the ABS module. Any ideas where I should begin looking? Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 28 Report Share Posted September 28 as far as the brake dragging check the rubber hose that connects to the caliper has been reported they can build up rust that holds the hose to the brace builds up under the bracket cutting off pressure to the unit,,,also have you removed the slide pins in the caliper to make sure they are clean and greased properly,or you might just need to replace the caliper as well.....fixing this first might solve your other problem if not I would take that to the dealership Quote Link to comment Share on other sites More sharing options...
Dean H Posted September 29 Report Share Posted September 29 (edited) You need a bi-directional scan tool. Capable of communicating with all of the electronic modules. 2016 DJ CODE INFORMATION: U0002-88-CAN C BUS OFF PERFORMANCE - BUS OFF. When Monitored: This diagnostic runs continuously when the following conditions are met Ignition on. No under voltage codes. Set Conditions: Anti-lock Brake Module (ABS) Module detected a catastrophic failure on the CAN bus. Default Actions: ABS is disabled. Possible Causes: CAN BUS CIRCUITS OPEN OR SHORTED. CODES RELATED TO BATTERY VOLTAGE, IGNITION, OR VIN MESSAGES. BODY CONTROL MODULE (BCM) POWER AND GROUND. BCM NOT CONFIGURED CORRECTLY. BODY CONTROL MODULE (BCM). MODULE THAT SET THIS DTC. Edited September 29 by Dean H Quote Link to comment Share on other sites More sharing options...
