StevenG_2009SXT Posted Friday at 08:39 PM Report Share Posted Friday at 08:39 PM I start with the car locked and headlight switch in the OFF position. Then I press the key fob unlock button once and the driver door unlocks. Unfortunately the headlights turn on. If I open the door, grab what I forgot, then press the key fob lock button, the headlights stay on. They eventually go out but sometimes not until the battery is drained and I need a jump start. How can I reduce/eliminate the automatic headlight on "feature". I don't have the fancy EVIC controls so the part of the manual that reads "The headlight delay time is programmable on vehicles equipped with the EVIC" doesn't apply. Is it not something that can be changed? Aside from the expense of replacing the battery often it's just a PITA to get to. There is an AUTO setting on the headlight switch but I just use the ON and OFF settings. It would be really nice if OFF actually turned off the headlights... Quote Link to comment Share on other sites More sharing options...
diymirage Posted Saturday at 12:39 AM Report Share Posted Saturday at 12:39 AM It's called approach lighting, shouldn't last more then 90 seconds at most I bet you could shut it off with alfaOBD Quote Link to comment Share on other sites More sharing options...
2late4u Posted Saturday at 10:18 PM Report Share Posted Saturday at 10:18 PM there is a setting in my 2014 in the info section, i believe it is around 20 seconds or a bit more Quote Link to comment Share on other sites More sharing options...
